The Einhell GC-HM 400 Hand Push Lawn Mower is a robust, functional lawn mower without a motor drive, for the clean, quiet and also environment-friendly mowing of lawns of up to 250m² in size. The ball-bearing mounted mower spindle with 5 high-grade steel blades is designed for a cutting width of 40cm. The cutting height adjustment facility with 4 levels can be adjusted to individual requirements.
The cylinder lawn mower has lawn-friendly large wheels. A curved long handle provides optimum on-the-job ergonomics. There is a parking position for easy and secure storage of the lawn mower. The 27 litre grass catch basket is removable and easy to empty.
Specifications:
Collection Container Volume: 27 litre.
Cutting Width: 40cm.
Max. Recommended Lawn Area: 250m².
Mowing Spindle Diameter: 125mm.
Cutting Height (Min./Max.): 13mm/37mm, 4 steps.
Weight: 7.5kg.
Web Attribute Set Cordless Lawn Mowers & Scarifiers
EAN Barcode 4006825651959
