The Einhell GC-SR 12 Multi-Purpose Spreader enables you to distribute fertilizers, seeds or winter grit quickly and evenly. Its high-grade, impact-resistant plastic housing is resistant to both corrosion and weathering. Fitted with a double push bar for effortless guiding. Spring locks on both sides enable storage in small spaces and there is also an adjustment lever for regulating the distribution rate.
Specification:
Spreading Width: 45cm.
Capacity: 12 litre.
Wheel Ø: 200mm.
Weight: 2.49kg.
Web Attribute Set Cultivation
EAN Barcode 4006825635065
