The Einhell GE-CM 36/33 Li Power X-Change Lawn Mower is recommended for lawns up to 250m². Five-stage central cutting height adjustment permits the simple, individual adjustment of the cutting height. The long-lasting housing consists of high-quality, impact-resistant plastics.
Equipped with a foldable push handle with high-speed clamping levers and can be adjusted in height. Its large-area wheels additionally preserve the lawn. The large grass box is equipped with a filling level display, so it can be seen immediately, if emptying is necessary. A practical carry handle provides a simple transport.
Supplied with: 2 x 18V 2.5Ah Batteries and 2 x High-speed Chargers.
Specifications:
Cutting Width: 33cm
Cutting Height Adjustment: 5 Stages: 25-65mm
Grass Box Capacity: 30 litre
Max. Recommended Lawn Area: 250m²
Weight: 11.55kg
Battery Capacity 2.5 Ah
Battery Voltage 36 V (2 x 18 V)
Sound Power Level LwA [Uncertainty K] 92 dB(A)
Batteries Included 2
Battery Type Li-ion
Sound Pressure Level LpA [Uncertainty K] 80 dB(A)
Web Attribute Set Cordless Lawn Mowers & Scarifiers
EAN Barcode 4006825645002
