The Kapro 787 Series Level Set is a comprehensive and versatile 4-piece toolset designed to meet all your leveling needs with precision and ease. Featuring the renowned Kapro 787 Helius Level, this set is equipped with three solid acrylic shockproof vials—one horizontal and two vertical—ensuring accurate measurements every time. The innovative wall grip feature allows you to hold the level against a flat surface with one hand, preventing scratches or damage to the wall. Additionally, the shock-absorbing rubber end caps protect the level from damage if accidentally dropped.
This 4-piece Kapro 787 Series Level Set includes a range of levels to suit various projects. The Kapro 787 Helius Level 600mm (24) is perfect for smaller projects, providing precise measurements with its solid acrylic shockproof vials. For medium-sized tasks, the Kapro 787 Helius Level 1,200mm (47) offers the same high-quality vials and durability. The Kapro 787 Helius Level 1,800mm (71) is suitable for larger projects, ensuring accuracy over longer distances. Additionally, the set includes a Kapro Cast Boat Level 250mm (10), featuring two solid acrylic shockproof vials (horizontal and vertical) and a tough yet lightweight cast aluminum body, making it perfect for compact spaces.
The heavy-duty padded carry bag with a strap is designed for convenience and protection, allowing you to transport your levels easily and safely. The wall grip feature of the levels ensures that you can hold them against a flat surface with one hand, preventing any scratches or damage to the wall. The shock-absorbing rubber end caps protect the levels from damage if they are accidentally dropped, enhancing their durability and longevity.
Web Attribute Set Levels
EAN Barcode 7290100854921
