The Stabila 96-2 extra strong double plumb spirit levels are designed for demanding professional use, featuring a reinforced light metal rectangular box profile with integrated gripping ridges for secure handling.
They are fitted with removable two-component end caps, incorporating patented anti-slip stops to ensure stability when marking and positioning.
Each level includes three precision vials (2 vertical and 1 horizontal) for accurate measurement in multiple orientations. Models up to 1,200mm include two milled measuring surfaces for enhanced accuracy, while longer levels are supplied without milled surfaces.
Set Includes:
1 × Stabila 96-2-60 Spirit Level (15226) – 600mm
1 × Stabila 96-2-120 Spirit Level (15229) – 1,200mm
1 × Stabila 96-2-180 Spirit Level (15230) – 1,800mm
Web Attribute Set Levels
EAN Barcode 4005069173791
