The Clearview LED work light is fitted with 6 x 2W LED's giving a high light output and a 40,000 hour service life. The light is fitted with a reinforced lens for high crack resistance. The head is made to IP65 standards, so is highly dustproof and liquid splash proof. It is also fitted with a 1.8m cable and 13A plug. The base has four holes spaced at 60mm centres for fixing directly to a bench or machine. Alternatively, there is an optional choice of a circular magnetic mounting base which screws onto the bottom of the lamp, an L-shaped bracket for fixing to a vertical surface or a screw clamp for fixing to a bench top. The total arm length is 525mm.
Axminster LED Clearview Work Light
| Corded or Cordless | Corded |
| Cable Length | 1.8 m |
| Web Attribute Set | Lighting |
| EAN Barcode | 5052511063932 |
