Don’t let its size fool you — the Lighthouse Mini Torch packs a serious punch. Whether you're heading outdoors, facing an emergency, or tackling everyday tasks, this ultra-portable torch delivers powerful illumination right when you need it.
With a brilliant 1,000 lumen output and a beam range of up to 110 metres, it lights the way with ease. Weighing just 100g, it slips effortlessly into your pocket or clips onto your bag for convenient, on-the-go use.
Choose from four lighting modes — 25%, 50%, 100%, and TURBO — to suit any situation. Powered by a durable 700mAh Li-ion battery, it offers up to 10.5 hours of runtime on a single charge. A built-in charge indicator ensures you're never left in the dark.
Crafted from tough aluminium alloy, the torch is built to withstand knocks, drops, and the demands of daily use.
Perfect for camping, hiking, or everyday carry, the L/HMT1100R Mini Hand Torch is your reliable companion for any adventure.
Includes: 1 x USB-C Charging Cable
Specifications:
Brightness: 1,000 Lumens
Beam Distance: 110m
Water Resistance: IPX4
Impact Resistance: 1m
Battery Capacity 700 mAh
Battery Type Li-ion
Web Attribute Set Torches, Headlights & Batteries
EAN Barcode 5023969014395
