The Lighthouse Rechargeable LED Pocket Torch combines powerful illumination with sleek portability. Producing a bright, super-white 120 lumen beam, it offers effective visibility up to 100 metres. Crafted from high-grade aluminium, its compact and lightweight design makes it easy to carry, while the intuitive rotating collar switch allows for seamless operation. Powered by a rechargeable 3.7V 350mAh Li-ion battery, the torch runs for up to four hours on a full charge. Charging is straightforward—just unscrew the tail cap and plug into any USB power source. The integrated charge indicator glows red while charging and switches to green when ready. It can be topped up anytime to stay prepared. Measuring just 97 x 27mm, this pocket-sized torch is ideal for everyday use, whether at home, work, or outdoors.
Specification
Output: 120 lumens
Run Time: 4 hours Max
Beam Distance: 80/100m
Power: 1 x Li-ion 3.7V 350mAh rechargeable
Charge Time: Approx 2 hours
Dimensions: 97 x 27mm
Battery Voltage 3.7 V
Batteries Integral
Battery Type Li-ion
Web Attribute Set Torches, Headlights & Batteries
EAN Barcode 5023969311999
