The Axcaliber range of Contract TCT (Tungsten Carbide Tipped) circular saw blades offers an unmatched blend of choice, cutting performance and price.
Manufactured in one of the most advanced facilities in the world, they are produced to the highest standards using the finest materials available. With the range covering everything from hand held power tools right up to large panel saws used in production workshops, you will be certain to find
a blade to suit every requirement. Bore size 30mm. A range of bore reducing bushes are available. These negative rake blades are a perfect choice for a mitre saw, the rake of the tooth will help prevent the blade from grabbing, creating a smoother, safer cut. The finish is 1st class on all natural timbers or man made boards.
Blade Diameter 305 mm
Maximum RPM 4,400 rpm
Kerf 3.2 mm
Teeth 72
Tooth Format TCG
Plate Thickness 2.2 mm
Hook Angle 5 Negative Rake
Bore Size 30 mm
Blade Application Negative Rake (72 teeth)
Web Attribute Set Circular Saw Blades
EAN Barcode 5052511000395
