This Crown Guard is suitable for blades of 250/254mm (10). It has a single bolt fixing and will fit on the riving knife of most circular saws. The guard has a 63mm extraction outlet at the rear allowing you to connect a dust extractor. Assuming the saw already has an outlet below the blade, the extra point of extraction makes for a much cleaner and safer working environment.
Web Attribute Set Saw Bench Accessories
EAN Barcode 5052511119547
