Keep your workshop cleaner and safer with the Axminster Flex Variable Height Extraction Stand. Designed for woodturners and woodworkers, this versatile dust extraction stand is to be used paired with the Axminster Extraction Hoods to capture airborne dust at the source, helping to improve air quality while turning, sanding and cutting.
The stand adjusts from 750mm to 1,200mm, allowing you to position the hood exactly where it's needed. A sturdy three-leg base provides excellent stability, even on uneven workshop floors, while remaining lightweight enough to move wherever effective wood dust extraction is needed. The stand is compatible with 100mm hoses.
Ideal for reducing airborne dust and maintaining a cleaner, healthier working environment, the Axminster Flex Variable Height Extraction Stand is a simple yet effective upgrade for any workshop.
Web Attribute Set Dust Extraction Hoods
EAN Barcode 5052511146772
