The MICROJIG FITFINDER Accessory Upgrade Kit is a practical woodworking measuring upgrade that expands the capabilities of the FITFINDER 1/2 Gauge, allowing woodworkers to transfer dimensions more accurately and efficiently. Featuring four specialised tips and a quick-change adapter system, the kit helps users locate, transfer and mark centre points with greater precision when setting up router bits, saw blades, fences and other workshop tools. Designed for a range of woodworking applications, these precision setup accessories help eliminate guesswork and speed up machine setup for more consistent results.
Web Attribute Set Miscellaneous Gauges
