Modified geometry tooth design, minimises burning and tolerates aggressive feed rates. For accurate pattern cutting the tooth profile expels chips extremely fast, leaving a very smooth finish. These blades can be used successfully on soft and hard wood up to 75mm thick. They are also well suited for plastic. Overall blade length 130mm.
For more information on each blade please see 'Information Downloads' below.
Scroll Saw Blade Length 130 mm
Size & tpi 1R - 13.7
Size & Ref Number (1R) - 90.439
Banding Thickness 0.30mm Web Attribute Set: Scroll Saw Blades
EAN Barcode 5052511096077
