Progressive tooth blades are versatile, performing well in wood, plastic, bone, Corian® and most fibrous materials. These blades feature fine entry teeth to avoid splitting or tear-out and have coarser teeth in the centre to clear the waste. Perfect for coated materials or veneered surfaces, they give a very clean internal cut. Thickness of work ranges from 1.5mm to 60mm. Overall blade length 130mm.
Pegas
Pegas Regular Progressive Scroll Saw Blades
| Scroll Saw Blade Length | 130 mm |
| Grade | Fine |
| Web Attribute Set | Scroll Saw Blades |
| EAN Barcode | 5052511096374 |
