Spiral blades are able to cut around the entire periphery of the the blade due to a helical shape. This design allows work to be fed in straight moves. The work does not have to be turned to make cuts, so sharp inside corners can be created. Excellent for wood, plastic, metals, bone, wax and more. Overall blade length 130mm.
For more information on each blade please see 'Information Downloads' below.
Scroll Saw Blade Length 130 mm
Size 2/0
Size & tpi 2/0 - 56 tpi
Size & Ref Number (2/0) - 90.500
Banding Thickness 0.70mm Web Attribute Set: Scroll Saw Blades
EAN Barcode 5052511096114
