This Perform 216mm Saw Blade Package comprises of 1 x 36-tooth 2.2mm kerf blade and 1 x 56-tooth 2.2mm kerf blade, both negative rake. Negative rake blades are great for mitre saws as the rake of the tooth helps to prevent the blade from grabbing, pushing material backwards to create a safer cut.
They are both Teflon coated blades, which helps to reduce heat and friction.
Blade Diameter 216 mm
Web Attribute Set Circular Saw Blades
EAN Barcode 5052511143184
