For a steady work surface wherever you need it, the SawStop Compact Table Saw Folding Stand features wide footing and non-skid rubber feet for stability and folds down flat for easy transport. This stand features wide footing and non-skid rubber feet for enhanced stability, ensuring your work is always secure. Despite its sturdy construction, the stand is lightweight and folds down flat for easy transportation and storage. Custom-designed ergonomic brackets make it simple to lock your saw into place, offering both convenience and reliability.
This lightweight and portable stand is designed with wide footing and non-skid rubber feet for stability. It folds down flat for easy transport and storage, with stowed dimensions of 140mm 667mm x 997mm. The custom-designed ergonomic brackets make it easy to lock your saw into place, ensuring a secure and stable setup.
Overall L x W x H 666.75mm x 2.49mm x 17.80mm (Folded dimensions) 11.90mm x 762mm x 609.6mm (Opened dimensions without saw on top)
Web Attribute Set Saw Bench Accessories
EAN Barcode 857555005772
