The SawStop Jobsite Saw Standard Zero Clearance Insert is engineered specifically for the SawStop jobsite saw with a 254mm (10) blade. This insert provides zero clearance for accurate cuts and reduced tear out, ensuring a clean and precise finish every time. The one-push lockdown feature allows for tool-free operation, making it quick and easy to secure the insert in place. Positioning screws ensure a solid and precise fit in the table, while pre-formed clearance slots accommodate the SawStop blade guard and riving knife.
This table saw insert measures 406mm in length and 25mm in height, providing a stable and reliable surface for your cutting tasks. The zero clearance design helps to minimise tear out, resulting in smoother and more accurate cuts. The one-push lockdown mechanism simplifies the installation process, and the positioning screws guarantee a secure fit. Additionally, the pre-formed clearance slots ensure compatibility with the SawStop blade guard and riving knife, enhancing the overall functionality of your saw.
Overall L x W x H 361.95mm x 104.77mm x 0.22mm
Web Attribute Set Saw Bench Accessories
EAN Barcode 857555005796
