The precision protractor head features a pointer and 90 notches in 1° increments each side of 0°, including one for 22.5° on each side. In addition, the built-in Vernier scale gives you the ability to fine-tune any angle in 1/10° increments.
The pointer-and-notch alignment mechanism locks in 181 precise angles. Anchor that to a premium adjustable mitre bar and add a heavy-duty extendable fence and micro-adjustable flip stop for making repeated cuts of the same length, and you have a premium mitre gauge that will take your woodworking to a whole new level of accuracy.
A 457.2mm (18”)-long mitre bar, made to fit in common 9.52mm (3/8”) x 19.05mm (3/4”) mitre slots, uses six adjustable washers to eliminate side-to-side wiggle in the mitre slot while ensuring a smooth glide forward and back. A screw-on T-clip at the front of the bar holds the bar level in the mitre slot when you pull the head off the table.
The aluminium mitre fence provides a larger reference for holding workpieces accurately (compared to the head alone), with a telescoping extension that reaches up to 800.1mm (31-1/2”), 863.6mm (34”) with the flip stop). A T-slot in the front face provides a place to attach auxiliary wood fences with T-bolts. The scale on top of the fence can be calibrated to enable making precise crosscuts without having to measure and mark your boards.
Use the flip stop to make repeated cuts at the same setting for identical project parts. The flip stop indexes on the fence with a tooth-and-notch system that lets you position it in 0.79mm (1/32”) increments. The flip stop’s dual arms can be set independently at different lengths from the blade or linked together with a rod, all of which can be fine-tuned with a built-in micro-adjuster
The package includes a mitre gauge with an extendable fence, a dual-arm flip stop, a reversible ruler for the main fence (362mm), a reversible ruler for the fence extension (457mm), 1x 24mm steel rod, 2x 38mm steel rods, 1x 3mm hex wrench, and 1x 5mm hex wrench.
