The WM-200 gives angle setting with pin point accuracy from 15 to 75 on grindstones of 6 to 10 in diameter, thus taking into account wear after years of use. The WM-200 is also provided with angle checking notches around its edge to enable bevel angles to be repeated or progress checked. (Supplied as standard with 1206, 2006 and T-7).
Web Attribute Set Powered Sharpener Accessories
EAN Barcode 7392485002536
