A tool post is required to support the Woodcut Tools Bowlsaver Max 4 on your lathe. The tool posts are available in different diameters to suit a number of lathes. Please check your lathe before ordering,
The tool post screws into the base of the platform of the Bowlsaver Max 4 and locates in your tool rest banjo. The tool rest is supplied with a locking collar. This is set and forget, it enables you to set the platform height to suit your lathe. Once set it ensures the Max 4 is at the correct height every time you use it.
Tool Post Diameter 25 mm
Web Attribute Set Woodturning Lathe Accessories
EAN Barcode 9421905382557
