For serious cutting tasks
Built for professional workshops and demanding applications, this panel saw combines robust construction with precision engineering to deliver reliable, high quality results. From smooth, accurate cutting performance to enhanced safety and ease of use, every feature is designed to help you work more efficiently and achieve consistently excellent finishes across a wide range of materials.
Buy with confidence
Solid build quality
Solid build quality
The saw features a solid steel chassis, a 535 x 800mm cast iron main table and a frame mounted trunnion system for long term reliability and increased stability, helping to reduce vibration.
Twin motor
Twin motor drive system
The twin motor drive system powers both the 315mm main blade and 120mm scoring blade independently to produce clean, precise cuts with reduced tear out, especially when working with veneered boards, laminates and other delicate surfaces.
Generous capacity
Generous capacity
Handle a wide range of tasks effortlessly with its generous cutting capacity. It offers up to 900mm of ripping width and a maximum cutting width of 1,260mm using the fence - making it ideal for working with large sheet materials.
Precision gliding table
Precision sliding table
The smooth gliding sliding table measures 1,600 x 360mm with a full 1,600mm stroke, providing excellent support for large panels, helping to improve handling and cut quality.
Heavy duty crosscut fence assembly
The heavy duty crosscut fence features a large section fence with robust, adjustable stops, allowing fast setup and highly repeatable crosscuts.
Integrated overhead crown guard
The integrated crown guard helps improve safety, whilst also improving extraction efficiency. Fitted with a 125mm dust outlet, the machine requires a minimum airflow of 1,500 m³/hr to maintain a cleaning working environment.
Not sure which machine is right for your task?
Explore our machinery classification page to compare classification options and ensure you select the best machine for your needs.
Discover more
Built for demanding workshop use, the Axminster Professional AP315CPS 315mm Panel Saw combines precision engineering with a robust construction to deliver accurate, repeatable cutting performance across a wide range of sheet materials. A twin motor drive system powers both the 315 mm main blade and the 120 mm scoring blade independently, running at 4,500 rpm to produce clean, precise cuts with significantly reduced tear out, particularly when working with veneered boards, laminates and other delicate surfaces. The blade tilts from 0-45° and offers an impressive maximum depth of cut of 95 mm at 90° and 67 mm at 45°, giving excellent versatility for both straight and angled work.
Handling large panels is made easier thanks to the 1,600 mm precision sliding table, engineered for smooth travel and rigidity to support wider workpieces and maintain cut accuracy. The heavy duty crosscut fence assembly features a large section fence with robust, adjustable stops, allowing fast setup and highly repeatable crosscuts. For ripping operations, the reinforced steel frame supports a generous cutting capacity, offering up to 900 mm ripping width and a maximum cutting width of 1,260 mm with the fence in position. This makes it ideal for wide sheet materials.
An integrated overhead crown guard protects the user while also improving extraction efficiency. The machine is fitted with a 125 mm dust outlet and requires a minimum airflow of 1,500 m³/hr to maintain a clean working environment.
Constructed for long term reliability, the saw features a solid steel chassis, a cast iron main table measuring 535 x 800 mm, and a frame mounted trunnion system for increased stability and accuracy. The sliding table measures 1,600 x 360 mm with a full 1,600 mm stroke, while the machine’s substantial 400 kg net weight further contributes to vibration free operation and precision cutting.
Powered by a 3 kW motor and supplied for 230 V operation with a 16 amp plug fitted, this panel saw is designed for serious workshop environments. It provides a durable, high performance, compact solution for cabinetmakers and joiners who require accuracy, capacity and reliability in their work.
Please note, if you require an EU plug, please ensure you purchase 113776
Blade Tilt 0 to 45
Dust Extraction Outlet 125 mm
Max Depth of Cut @ 45º 67 mm
Max Depth of Cut @ 90º 90 mm
Max Width of Cut with Fence 1,260 mm
Overall L x W x H 2,030 x 2,550 x 860mm
Power 3.0 kW
Rating Frequent Use
Table Height 880 mm
Table Size 535mm x 800 mm
Blade Diameter 315 mm
Min Extraction Airflow Required 1,500 m³/hr
Sound Power Level LwA [Uncertainty K] 85.7 dB(A)
Blade RPM 4,500 rpm
Sound Pressure Level LpA [Uncertainty K] 100.7 dB(A)
Plug Fitted UK 16A Plug
Web Attribute Set Panel Saws
EAN Barcode 5052511142439
  • UK Mainland - £70
