Perfect for any woodworking enthusiast
Looking for a scroll saw that can do it all? The AW457SS is perfect for intricate woodworking projects whilst still accommodating larger ones. It ensures smooth and accurate cutting for excellent results.
Buy with confidence
A close-up of a person's hand adjusting a knob on the control panel of a black and silver industrial machine, with red and green power switches visible.
Variable speed
The variable speed capacity, ranging from 550 to 1,550 strokes per minute, enables the machine to handle various materials, providing full control over cutting speed.
A close-up action shot of a woodworker using a scrollsaw with a clear protective guard. The person's hand and back are visible as they guide a piece of light-colored wood through the machine in a workshop setting.
Large cutting capacity
The AW457SS features a 350 x 540mm table, a 457mm throat depth and a 20mm stroke length, ideal for larger projects.
A workshop scrollsaw with a white upper frame, black tabletop and guide, and a red lower cabinet, shown on a light wood tabletop against a wood plank wall.
Stable build
The base is crafted from heavy gauge steel plate, ensuring minimal vibration for your projects
A close-up of a red scrollsaw with a flexible black hose connected to a blue vacuum hose, set on a light wood surface against a wood-panelled background.
Dust extraction
Connect your scroll saw using a vacuum cleaner via the 37mm diameter dust port to ensure safe working.
A person operating a red scrollsaw with a clear guard, working on a piece of wood on a workbench against a wood-panelled background.
Tilting & raised arm
The arm tilts to a 45° angle in both directions while the table remains flat, ensuring easier and more precise cutting. It also raises, ensuring quick blade threading when making internal pierced cuts.
A tabletop scrollsawwith a white upper arm, black cutting bed, red base, and clear protective guard, shown on a light wood table against a wood-panelled wall. A circular metal template with engraved floral patterns rests on the table near the machine.
Simple blade changing
The saw is excellent for cutting wood, metal and plastic, subject to the correct blade being used. The blade changing is simple thanks to a quick release tension knob.
A close-up of a scrollsaw machine in action, carving decorative star and flame patterns onto a light-coloured wooden board.
Choose from a selection of scroll saw blades
From wood-cutting to metal-cutting, explore our wide selection of high-performance blades, available in a variety of TPI (teeth per inch) configurations to suit every material and application.
Shop now
The Axminster Workshop AW457SS Scroll Saw is a versatile and precise tool, ideal for intricate woodworking projects.
Powered by a 120W motor, it ensures smooth and accurate cuts with stroke length of 20mm. With adjustable strokes per minute ranging from 550 to 1,550/min, you have full control over the cutting speed and can cut materials up to 50mm deep.
The table is 350 x 540mm with a 457mm throat depth. The arm tilts to 45 in both directions, for bevel cutting and is ideal for handling larger workpieces. The arm also raises to ensure quick blade threading when making internal pierced cuts. The base and table are made from a heavy gauge steel plate, giving stability and helps to reduce vibration.
The saw accepts pinned or plain end blades. The clamps are easily accessible for blade changing. Additionally, the 37mm dust extraction outlet keeps your workspace clean and free of debris when paired with a vacuum, making this scroll saw a valuable addition to any workshop.
Suitable for wood, metal and plastic when using the correct blades.
Please note, if you require an EU plug, please ensure you purchase 113504
Dust Extraction Outlet 31 mm I.D. / 37 mm O.D.
Max Depth of Cut @ 90º 50 mm
Overall L x W x H 760 mm x 350 mm x 440 mm
Rating Regular Use
Stroke Length 20 mm
Table Size 350 mm x 540 mm
Table Tilt 45 - 0 - 45
Throat Depth 457 mm
Motor Power 120 W
Plug Fitted UK 3 pin plug
Web Attribute Set 230V Scroll Saws
EAN Barcode 5052511136612
