Axminster Adjustable Try Square
SKU: 106477
£38.28
£31.90 Excl. VAT
  • Adjustable square offers a lifetime of accuracy
  • Re-calibrate and re-tune any time
  • Two small screws adjust blade relative to stock
  • 3mm thick x 30mm wide solid brass blade
  • Brass-faced, laminated bamboo stock 75 x 38mm
  • Most useful size for general layouts and machine setup
  • Overall, size 142 x 80mm
This is a real gem of a square; any woodworker will appreciate this tool. It has a wonderful weighty feel with its 3mm thick solid brass blade and 75 x 38mm brass-faced, laminated bamboo stock. The inner edge of the blade is 105mm long, which is a good size and great for general layouts and machine setup.
Loss of accuracy, due to an accidental knock or drop would render a standard square useless, the only remedy being grinding or filing the blade. This handy square overcomes the problem; two small screws at the base of the stock allow you to adjust and re-calibrate the blade relative to the stock. A fraction of a turn on each is all that is required. This means the square will give you a lifetime of accuracy.
Overall, size 142 x 80mm, blade width 30mm.
Additional Accessories No
Made in Britain Yes
Web Attribute Set Squares
EAN Barcode 5052511119110
