Axminster Combination Square Set 300mm (4 Piece)
SKU: 105405
£46.38
£38.65 Excl. VAT
  • All round tool for setting out, measuring and marking
  • Cast iron square and mitre stock
  • Cast iron centre finder and protractor
  • 300mm metric only scales with pearl chrome finish
  • Precision machined
  • Supplied in plastic storage case
An indispensable addition to any workshop, this 300mm metric combination square set is a versatile tool for accurate measuring, marking and setting out. Ideal for woodworking, engineering and general workshop use, it provides everything needed for checking 90° and 45° angles, finding centres, measuring depths and setting or transferring angles.
The precision machined cast iron square head offers reliable 90° and 45° reference faces, while the 300mm steel rule features a pearl chrome, non-reflective finish with clear metric graduations for easy reading in all lighting conditions. This comprehensive 4-piece set includes a square and mitre head, centre finder and precision protractor head (all cast iron), giving you the flexibility to tackle a wide range of layout and inspection tasks with a single measuring system. Each head is fully adjustable up and down the rule and locks securely in position for repeatable accuracy.
Supplied in a robust plastic storage case, the set keeps all components organised and protected when not in use, making it an excellent choice for both the professional workshop and the serious home craftsman.
Additional Accessories No
Web Attribute Set Combination Squares
EAN Barcode 5052511109005
