Axminster Engineer Series Dial Gauge
SKU: 310453
£21.58
£17.98 Excl. VAT
  • 50mm diameter
  • 10mm travel
  • Two movable setting tabs
  • Mounting by 8mm diameter stem or 1/4 hole on back
A high precision 50mm diameter dial gauge with a 10mm travel, one millimetre per revolution sub divided into tenths and hundredths giving a resolution of 0.01mm per division. There are two movable setting tabs on the dial and a bezel which can be rotated for zero setting. Mounting is either by the 8mm diameter stem or by using the lug on the rear with its 1/4 diameter hole.
Web Attribute Set Dial Indicators
EAN Barcode 5052511011988
