Axminster Vernier Caliper - 150mm
SKU: 910359
£21.98
£18.32 Excl. VAT
  • Stainless steel with satin finish
  • Clear metric and imperial graduations
  • Metric scale gives readings down to 0.02mm and the imperial scale 0.001
  • Can be used for external, internal and depth measurement
A good quality vernier caliper made from stainless steel with clear metric and imperial graduations and a satin finish to eliminate glare. The metric scale gives readings down to 0.02mm and the imperial scale to 0.001. The caliper can be used for external, internal and depth measurement and the locking screw keeps the head secure between measurements. Supplied in a plastic case.
Web Attribute Set Measuring Calipers Measuring Range: 0 mm to 150 mm
EAN Barcode 5052511044542
