Tracer Marking System
TRACER TRUESHOT Marking Kit
SKU: 114376
£9.64
£8.03 Excl. VAT
  • Innovative construction marking tool
  • Mark inside holes up to 100mm
  • Unique and precise crosshair mark
  • Chalk canister with up to 350 shots
  • Safety lock prevents accidental marks
  • Impact-resistant ABS body
The TRACER TRUESHOT Marking Kit is a next-gen professional marking tool, which delivers fast, accurate chalk marking in hard-to-reach areas. It's a deep-hole chalk marker, capable of marking inside holes up to 100mm deep, reaching where traditional markers and pencils can't. The TRUESHOT Marking Kit uses a unique crosshair marking system, which leaves a bright green chalk crosshair, that's precise and highly visible even on dark or uneven surfaces. The crisp, splatter-free chalk mark is what makes this a precision marking tool. It also features a three-stage locking system - spray, lock and replace - to prevent accidental marks or leaks.
The TRACER TRUESHOT has an impact-tested ABS body for jobsite durability, and a textured grip, pocket clip, and lanyard hole for convenience. It comes with a long-lasting replaceable chalk canister which holds up to 350 shots, and can be removed and recycled when complete, before fitting a new refill (sold separately).
TRACER offers trusted measuring and marking solutions for construction professionals, designed with real jobsite challenges in mind. With solutions including the TRUESHOT Marking Kit, TRACER develops innovative products that tradespeople work with greater accuracy and efficiency.
Web Attribute Set Marking Pencils
EAN Barcode 5060668274583
