A spare MkII Parf stick, which some may find other uses for. The accuracy of the UJK Parf system is dependent on the very tight tolerance of the holes in these sticks. The Mk II drill guides locate positively into holes in the Mk II Parf Stick. The UJK Parf system uses holes at 96mm centres, the MkII stick has additional holes 32mm or 48mm centres offering the possibility of drilling intermediate holes at or holes for predetermined angles other than 90
UJK
UJK Parf System Mk II Stick - 1m
| Intended Use | Used in conjunction with the Parf Guide System to produce dog holes. |
| Web Attribute Set | Festool CMS Moduler System and MFT Table Accessories |
| EAN Barcode | 5052511126071 |
