Silicon Carbide grain coated onto two sides of a low density foam to enable a premium finish on profiled or flat surfaces. Used wet or dry, they are excellent for preparation of surfaces prior to recoating. Available in 60, 100,180 and 220grits. Size approx 98 x 120 x 13mm.
Mirka
Double-Sided Sanding Sponge
| Abrasive Material | Silicon Carbide |
| Abrasive Backing | Foam |
| Abrasive Grit | 100 |
| Web Attribute Set | Sanding Pads & Sponges |
| EAN Barcode | 4038595755186 |
