The pointed pad of the Delta sanders give them easy access into corners and tight spots. The DEOS II 663CV takes things further with a compact, low profile, lightweight body, the perfect sanding solution even for an extended period. It is perfect for woodwork and decorative painting, and is ideal for use on doors and windows, corners, edges and tight spaces.
When it comes to those tight spots, the DEOS II 663CV is unrivalled. It makes sanding jobs faster, easier and more comfortable than ever before, especially when working on vertical areas. The 3mm orbit diameter and powerful, upgraded 300W brushless motor makes it the perfect tool for effective and fast stock removal. There is variable speed control ranging from 5,000 - 10,000 rpm, and the design makes it easy for the operator to change. LED indicators are located on the speed selector, together with a separate on/off switch and lockable speed for optimum control.
The low weight and exceptionally low vibration levels allow prolonged use without the prospect of aching muscles and tired shoulders. You can monitor vibration levels, in real-time with an enhanced Bluetooth connection to the myMirka app.
The use of Mirka's Abranet net abrasive and direct connection to a suitable extractor offers virtual dust-free sanding and minimal time spent cleaning up.
The 663CV delta sander comes with a Mirka Deco Solutions kit containing:
25 x Abranet ACE HD sheets in grit P80
25 x Abranet ACE HD sheets in grit P120
50 x Abranet sheets in grit P180
Dust Extraction 27 mm Outlet
No Load Speed 5,000 - 10,000 rpm
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 79 dB(A) [3.0 dB]
Corded or Cordless Corded
Cable Length 4.3 m
Sound Pressure Level LpA [Uncertainty K] 68 dB(A) [3.0 dB]
Vibration Sanding [Uncertainty K] 2.6 m/s² [1.5 m/s²]
Motor Power 300 W
Plug Fitted UK 3 pin plug
Web Attribute Set Delta Sanders
EAN Barcode 6416868519716
