Mirka Gold hook and loop backed 125mm discs are a durable product very well suited for sanding at high speeds. Gold is an all-round sanding material suitable for many applications, including wood, paint, lacquers, non-ferrous metals and plastics.
The Multifit hole pattern is designed to fit most backing pads, ensuring maximum dust extraction when used with a compatible vacuum system. To achieve an optimal sanding result, the semi-open grit binding and special stearate coatings prevent clogging and pill forming.
Coarser grits are recommended for sanding putty and removing lacquer, while finer grits are excellent for dry sanding primed or lacquered surfaces in preparation for following coats.
Available in various Grits and pack sizes of 10, 50 or 100
