The Kapex KS120 REB is compact and lightweight (only 21.5kg), but offers impressive cutting capacity and uncompromising accuracy. It is capable of cutting boards and panels up to 305mm wide and 88mm thick. Trimming crown mouldings up to 168mm in their original wall position does not present a problem.
Festool have taken the concept of the slide compound mitre saw and redesigned it into a compact, portable machine. The following preset mitre angles are available; left: 0, 15, 22.5, 30 and 45; right: 0, 15, 22.5, 30, 45 and 60. A twin-line laser beam shows you precisely where the blade will cut. Variable speed means you can adapt to different materials for the best cutting performance.
The main casting provides a firm foundation to support the twin bars, which support the saw head giving the saw its supreme accuracy and solid feel in operation. Incorporated in the base are also small pull-out side extensions that provide extra support to longer workpieces.
The machine is supplied with a 60-tooth blade (2.5mm kerf), a work clamp and an adjustable bevel, which transfers angles for interior and exterior angles and dissects angles automatically for easy saw setting.
Bevel Angle Range 47 - 0 - 47
Dust Extraction 27 mm / 36 mm Outlet
Mitre Angle Range 50 - 0 - 60
Overall L x W x H 713 mm x 500 mm x 470 mm
Rating Trade/Professional
Spindle Lock Standard Feature
Blade Diameter 260 mm
Sound Power Level LwA [Uncertainty K] 101 dB(A) [3.0 dB]
Blade RPM 1,400 - 3,400 rpm
Sound Pressure Level LpA [Uncertainty K] 88 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] 2.5 m/s² [3.0 m/s²]
Motor Power 1,600 W
Manufacturer Part Number 575304 & 575305
Voltage 230 V
Web Attribute Set Mitre Saws Mains Powered
EAN Barcode 4014549299234
