The professional CMT finger joint cutter head lets you make one of the most incredibly strong side-to-side joints in all wood and wood composites. The tightness of the accurately cut joint and the maximum glue surface create a joint that is actually stronger than an unworked piece of wood, in stock with max thickness of 47mm. Ideal for molding manufacturers and furniture makers. Cutting diameter 105mm, bore size 30mm.
Web Attribute Set Spindle Moulding Blocks & Knives
EAN Barcode 5052511038459
