This accessory is a simple alloy plate that lifts the workpiece above the table. This means that you can machine the top and bottom surface of the work, such as when creating a tenon. It can be mounted next to the mitre fence and clamp so as to make the machining of end grain material as safe as possible. Overall length 650mm x 120mm width.
Axminster Professional
Axminster Professional Tenoning Plate for AP200SM
| Overall L x W x H | 650 mm x 120 mm x 28 mm |
| Web Attribute Set | Spindle Moulders Tables |
| EAN Barcode | 5052511045860 |
