The MICROMOT MB 200 drill stand is made from diecast aluminium. It has a 20mm collar, which when used in conjunction with other 20mm collar PROXXON tools, it can be used for bevelled drilling and versatile milling operations. The head can be tilted through 90 allowing for diagonal drilling. The solid, hard chromium plated steel column measures 280 x 20mm and gives a throat capacity of 140mm. The table measures 220 x 120mm and has all holes pre-drilled and tapped to accept the KT 70 compound table. Weight 2.2kg.
EAN Barcode 4006274286009
