The Rotacraft 60 Pce Cutting & Grinding Set is a comprehensive accessory kit designed for a wide range of cutting and preparation tasks on smaller workpieces. Ideal for craft, modelling and light DIY applications, this set gives you the flexibility to tackle various materials with precision and control.
Compatible with most mini rotary tools, thanks to 2.35mm and 3.2mm shank sizes, the set includes a broad selection of grinding stones and wheels, reinforced cutting discs, carborundum slitting discs, along with mini steel and diamond circular saw blades. This combination makes it suitable for cutting, shaping and surface preparation across wood, metal, plastics and more. Compact and lightweight at 82g, with dimensions of 205 x 155 x 25mm, it’s easy to store and keep organised.
Rotacraft offers a wide range of precision tools and accessories designed for all skill levels, supporting applications from modelling and electronics to restoration and fine detail work.
Web Attribute Set General Mini Tool Accessories
EAN Barcode 5060030667715
