The DeWalt Multi-Tool wood and nails blade is suitable for use on nail embedded timber and resists damage to the teeth when encountering unexpected nails. The blade has a bi-metal construction, ensuring that it maintains a sharper edge for longer. The cutting depth maximises the areas that the tool and accessory can be used in. The blade is quick and easy to change, and can be used on most oscillating multi-tools. It is ideal for cutting wood with or without nails, plasterboard, PVC.
Blade length: 43mm
Blade width: 30mm
Web Attribute Set Oscillating Multi-Tool Cutting
EAN Barcode 5035048099247
