The UJK MRMDF Top for Bench dogs is 18mm thick, moisture resistant MDF. This material is versatile, lightweight and ideal for workshops with varying humidity. The UJK MRMDF top has a grid of 20mm plain chamfered dog holes: 11 holes by 7 holes 96mm apart. These holes are CNC machined to guarantee accuracy, aligned lengthways and widthways with the rows perfectly square to each other. These dog holes allow you to use bench dogs and many other accessory clamps, guide rails and stops to hold, saw, rout and machine your work with perfect accuracy. Made from 18mm thick MRMDF, the 1,102mm x 718mm top fits perfectly in the UJK Multifunction workbench frame or the Festool MFT base. This makes it a suitable replacement for the standard Festool top.
UJK
UJK Moisture Resistant MDF Top for Bench Dogs
| Overall L x W x H | 1,102 x 718 x 18mm |
| Made in Britain | Yes |
| Web Attribute Set | Portable Work Benches & Trestles |
| EAN Barcode | 5052511132171 |
