Ice Bear
Mokuba Japanese Reform Bar - 300mm
SKU: 200522
€15,00
  • Exceptionally strong tool, with many uses
  • Plenty of leverage to remove stubborn nails
  • Wide gently curved spatula shaped end, to gently pry or scrape
  • A great tool for those involved in renovation
An exceptionally strong tool, with a multitude of uses. The claw is used to remove nails, the flat surface immediately behind the claw can be struck with a hammer to help drive the claw under the nail head. This flat surface also doubles up as a hammer itself. 300mm long it develops plenty of leverage to remove stubborn nails. Opposite the claw is a wide gently curved spatula shaped end, use to gently pry or as a scraper. The shaft features a ring to attach a lanyard. A great tool for those involved in remodelling, where minimising damage means saving time and money.
Web Attribute Set Wrecking & Pry Bars
EAN Barcode 4960408008700
