Designed for use with the Axminster Auto Locking Emergency Off Switch, this robust emergency stop switch mounting plate provides a secure and convenient way to position your emergency stop switch within easy reach. Ideal for machinery installations, workstations and custom safety setups, it helps you find a practical mounting position to suit your equipment.
Manufactured from durable 3mm steel, the plate features a 90° return for added rigidity and versatile mounting options. The main plate measures 90 x 98mm, with a 90 x 32mm return flange, providing a sturdy platform that resists flexing during use.
Supplied undrilled, the mounting plate allows you to create fixing holes to suit your specific machine layout and installation requirements. It can be fitted to suitable machine stands, cabinets, benches and other structures, offering flexibility across a wide range of workshop applications.
Please note: The mounting plate is supplied without fixing holes. All mounting and switch fixing holes must be drilled by the user to suit the intended installation.
