The Festool KS 120 Multi-Function Stop Hold Down is a practical workholding accessory designed to improve stability and cutting accuracy when using the Festool Kapex KS 120 Sliding Compound Mitre Saw. By securely clamping workpieces in position, it helps deliver more precise and consistent results across a wide range of cutting applications.
Designed for use with the Kapex support system, the hold down applies secure downward pressure to prevent material movement during cutting. This enhanced stability improves safety, accuracy and repeatability, particularly when working with smaller sections, mouldings and finished materials.
Featuring a robust and easy-to-adjust design, the hold down enables fast positioning and quick setup changes while maintaining reliable clamping performance. It is particularly useful for repetitive cutting tasks where consistency and efficiency are essential.
Ideal for joiners, cabinet makers, furniture manufacturers and installation professionals, the KS 120 Multi-Function Stop Hold Down is well suited to trim work, crosscutting and repetitive production applications.
Compatible with the Festool Kapex KS 120 and associated support systems, providing an integrated solution for improved workpiece control.
Supplied with; Aluminium profiles, contact plates and splinter protection guards.
Manufacturer Part Number 578720
EAN Barcode 4014549463895
