The Festool KS120 Multi Function Stop Splinter Guards are genuine replacement inserts designed for use with the Festool KS 120 Multi-Function Stop system. They help maintain clean, precise cuts by reducing tear-out and splintering on both sides of the blade during cutting operations.
Over time, splinter guards can become worn or damaged through regular use. These replacement plates restore cutting performance and help achieve cleaner results when working with materials such as hardwood, softwood, veneered boards, laminates and decorative mouldings.
Designed specifically for compatibility with the Festool Kapex KS 120 system, the replacement plates are quick and easy to install, helping keep your cutting setup operating at its best. Genuine Festool components ensure a precise fit and reliable performance.
Ideal for professional tradespeople, installers, cabinet makers, furniture makers and woodworking enthusiasts who require consistently high-quality cut finishes from their Kapex mitre saw system.
Supplied as a pack of four replacement splinter protection plates for the KS 120 Multi-Function Stop. Multi-Function Stop and support system components are sold separately.
Manufacturer Part Number 578726
EAN Barcode 4014549463918
