The Faithfull 8mm Hook is securely mounted on a 50 x 50mm (2 x 2) steel plate, pre-drilled for quick and easy installation. Choose between a tough Black Japanned finish or a corrosion-resistant Galvanised coating—both designed to enhance durability across general-purpose hanging and fixing tasks.
N.B. Hook accessories should not be used for any overhead lifting or load-bearing applications.
Finish Black Japanned
Web Attribute Set Padlocks & other locks
EAN Barcode 5023969277912
