The Faithfull 8mm Ring is mounted on a robust 50 x 50mm (2 x 2) pre-drilled steel plate, offering quick and secure installation. Choose from two durable finishes: corrosion-resistant Galvanised or tough Black Japanned—both designed to withstand general-use conditions in indoor or outdoor settings.
Please note: Ring accessories are not suitable for overhead lifting or load-bearing applications.
Finish Black Japanned
Web Attribute Set Padlocks & other locks
EAN Barcode 5023969277929
