Faithfull welded steel chains are designed with the link sides welded for added strength. Constructed from mild steel, the straight links are formed into an A-style short link chain and finished with a bright zinc plating for corrosion resistance. These chains are ideal for general-purpose use, such as securing loads. While they are test load tested, they are not certified and must never be used for overhead lifting, load binding, or towing. Maximum load figures provided are for guidance only
Web Attribute Set Padlocks & other locks
EAN Barcode 5023969255774
