The Axminster Professional SD315PS 3200mm Panel Saw is a highly versatile machine, ideal for sizing sheet materials, ripping solid timber and producing precise angled cuts. Built with a heavy duty construction, the saw delivers exceptional stability and vibration free performance, ensuring consistently accurate results.
A large 3,200 x 360mm sliding table, combined with an 800 x 1,330mm extension table, provides excellent support for a wide range of workpieces. The sliding table offers a full 3,200mm travel past the blade, making it easy to handle full-size sheets. The main cast iron table measures 800 × 530mm and, together with the extension, offers ample working space at a comfortable working height of 860mm.
Fitted with a 315mm blade running at 4,500rpm, the saw can cut up to 95mm at 90° and 67mm at 45°, with smooth and precise tilt adjustment from 0-45°. This makes it equally capable of cutting thick boards and carrying out complex joinery work. Power comes from a robust 3kW motor, delivering clean, efficient cuts with ease across a variety of materials.
The saw unit and motor assembly are housed within a reinforced steel cabinet, isolating mechanical stress from the cast iron table. This design ensures the table remains flat over time, maintaining cutting accuracy even under heavy workloads. A heavy duty aluminium extruded crosscut fence supports workpieces up to 3,900mm in length and includes two precision machined cast aluminium repeat stops for fast, accurate and repeatable cutting.
With a ripping capacity of 1,250mm and a sliding table stroke of 3,200mm, handling large panels is straightforward. A dual-motor system drives a dedicated 120mm scoring blade with a 20mm bore, producing flawless finishes on veneered and laminated panels.
For safety and dust control, the SD315PS panel saw is equipped with a fully adjustable overhead crown guard that provides clear visibility of the cutting area while capturing dust at source. A 120mm dust extraction outlet requires an airflow of 850m³/hr, helping to maintain a cleaner, safer working environment.
Please note, if you require an EU plug, please ensure you purchase 113776
Blade Tilt 0 to 45
Dust Extraction Outlet 120 mm
Max Depth of Cut @ 90º 95 mm
Max Width of Cut with Fence 1,250 mm
Overall L x W x H 6,700 x 5,410 x 1,500 mm
Power 3.0 kW
Rating Frequent Use
Table Height 860 mm
Table Size 800 x (530+800) mm
Blade Diameter 315 mm
Min Extraction Airflow Required 830 m/hr
Sound Power Level LwA [Uncertainty K] 85.7 dB(A)
Blade RPM 4,500 rpm
Sound Pressure Level LpA [Uncertainty K] 100.7 dB(A)
Plug Fitted UK 16A Plug
Web Attribute Set Panel Saws
EAN Barcode 5052511142538
This product is classified as a Large Delivery product and will normally be delivered within 14 working days.
This is a Bespoke Large Delivery service. Our team will contact you upon completion of your order to discuss carrier options and arrange a delivery date to suit you.
  • UK Mainland - £70
