Our most popular pen kits, and the reason for this is that they are good quality, reliable and when completed, make wonderful presents. The 10kt Twist Pen requires only half a turn to advance the mechanism, at the same time locking the mechanism in place so that the refill will not retract during use. A heavy, solid brass break resistant clip, plated with 10kt gold plate makes the pen more attractive. Each pen kit includes a tungsten carbide tipped refill to provide smooth, trouble-free writing. The 24kt Twist Pen is gold plated with a black clip and epoxy coated to give some additional protection to the plating. Requires 7mm drill. Use refill 310492. These pens can be turned using the bushes supplied as standard bushes with the Axminster Pen Mandrels.
Pen Kit Classification Scholar
Difficulty Beginner
Drill Bit Required 7 mm
Bushing Set Order No. 8.5mm O/D (as supplied with mandrel) (100793)
Minimum Blank Size 16 mm x 16 mm x 112 mm
Pen Type Twist Pen
Finish 24kt Gold (Black Clip)
Refill Order Number 310492
Colour Gold Web Attribute Set: Project Kits
EAN Barcode 5052511012169
