Penn State Industries
Clarion Demonstrator Fountain Pen Kit - Chrome
SKU: 107852
€17,00
  • Clear bottom barrel shows when it is time to refill
  • A great opportunity to use precious small off-cuts
  • Includes a pump for liquid ink and cartridge for easy ink replacement
The Clarion features a clear bottom barrel allowing you to see the cartridge or ink pump and ink level. You know at a glance when it is time to refill with ink. The top cap is your opportunity to show off your turning skills. The pen is fitted with highly polished stainless steel German made medium nib with an iridium tip for a great writing experience. The cap posts with threads on both ends. Includes a pump for liquid ink and cartridge for easy ink replacement. Minimum blank length is only 50mm, a great opportunity to use up those precious small off-cuts you have been saving. Drill bit required 12.5mm, recommended bushing set 107853.
Difficulty Intermediate
Drill Bit Required 12.5 mm
Bushing Set Order No. 107853
Minimum Blank Size 19 mm x 19 mm x 50 mm
Colour Chrome Web Attribute Set: Project Kits
