A big improvement when compared to a standard marking pencil. The Hultafors Dry Marker comes in a protective holster with a strong pocket clip, so it is always to hand and far less likely to get misplaced. Shaped to prevent it from rolling off a bench, the bright red colour makes it easy to find if you accidently drop it.
The ergonomic grip makes it easy to hold and control. The slender tip design is perfect for deep-hole marking. A hole in the bottom of the holster lets dirt and moisture fall out, and allows you to use the marker without removing it from the holster.
The Hultafors Dry Marker has a handy built-in sharpener under clip in the holster. The leads are quick and easy to change.
Length: 164mm, weight: 23g.
